Application Run Control: Blacklisted Applications
Blacklisted applications are blocked from running on a device. Other non-blacklisted application may run without interference. You can add many applications to a blacklist. You can also create many blacklists. You do this when:
Select Add and enter a name for your new list. In the Add an Application Name or Bundle Identifier table, start typing the name of the application or its bundle ID, and SOTI MobiControl provides search results you can choose from. Select Add to add a new row.
You can import lists in .csv format. In the .csv file, list each application starting with its bundle ID and then its name. You can also export lists and easily move them between SOTI MobiControl instances.
