SOTI Surf
Use this dialog box to configure settings for the SOTI Surf app when:
The SOTI Surf app shuts down (according to the delay set in Delay Application Update) and relaunches each time you update and assign the SOTI Surf profile configuration.
Branding
Select the Configure button to open the Brand Settings pane, where you can define SOTI Surf branding options.
| Enable Customized Branding | Turn this toggle on to display the branding options. |
| Primary Color | Select the primary background color for the SOTI Surf page, which appears when the app is loading. |
| Text Color | Select the text color for the SOTI Surf page, which appears when the app is loading. |
| Upload Logo | Browse for an image to serve as the app logo. You can also drag the image file and drop it into the field. |
| Use White Background | Turn this toggle on to display a white background on the splash screen. |
| Preview | This section enables you to preview the branding options you define. You can switch from a phone to a tablet image by selecting the corresponding icon on the section toolbar. |
Home Screen
With website filtering enabled on the profile configuration, websites configured as the home screen or as part of the home screen catalog are automatically added to the "allow" list.
- If a device has more than one home screen website enabled, the profile assigned first supersedes all others.
- If a device has more than one home screen catalog enabled, SOTI Surf adds all websites from all profiles to the catalog on the device.
- If a device has a website and a catalog enabled, the home screen website supersedes the catalog.
- If a device has a profile with the home screen enabled and another with it disabled, the profile with the enabled home screen supersedes the disabled setting.
- Corporate bookmarks from more than one profile become "unioned."
Turn on the Enable Home Screen toggle to control how the home screen of the SOTI Surf app appears to device users. Next, choose one of the following options:
- Catalog: provides a set of websites as links on the home screen of the app. You can group links into folders.
- Website: The home screen of the app is a single website.
| Websites | Add websites to appear as links on the SOTI Surf home page. Select New in the Websites table to add a new catalog entry. To delete a website, hover over its row and select Delete. Use the arrows to arrange the order websites appear on the SOTI Surf home screen. |
| Add Folders | Group websites into different folders. If you have a lot of
									websites, you can simplify the app home screen by placing
									website links into folders. Select New in the Add Folders table to create a new folder. On the Add Folders screen, enter a name for the folder and select New to add websites to the folder. Select OK once you've finished adding websites. You can add many folders and then arrange their order of appearance on the device screen. |
| Show Websites Before Folders in Catalog | Show website links before folders on the home screen of the app. |
| Home Screen URL | Enter the URL of the website that you want as the SOTI Surf home page. |
| Configure Corporate Bookmarks | Add websites as bookmarks to SOTI Surf. Select
									New in the Configured Corporate
										Bookmarks table to create a new row. Enter a
									display name and the website's URL. Listed websites appear as
									corporate bookmarks. To delete a bookmark, hover over its row and select Delete. Use the arrows to arrange the order websites appear on the SOTI Surf bookmarks menu. |
Scripting
You can send JavaScript scripts to the SOTI Surf browser to customize the behavior of certain URL's web applications.
Select the Configure button to open the Scripting pane.
| Enable Customized Scripting | When enabled, you can configure a Javascript script to send to SOTI Surf. Once received, SOTI Surf uses the Javascript script to
									customize the behaviour of specified URLs. Select to add and configure a new script. When you configure a new script, you need to do the following:
 Once you have at least one script selected, you can
										choose to enable/disable URL-script name associations as
										needed.  Note: When a URL receives more
											than one script, the script contents do not replace
											another. Instead, each of the script's contents combine.
											When there are scripts with conflicting changes, the
											last in order (the most lowest URL-script name
											association row) script executes. Then select
											Save to complete the script
										assignment. |
| Auto Hide Top and Bottom Bar | When enabled, device users can not see or access the top and bottom bars of SOTI Surf. |
| Full Screen Mode | When enabled, SOTI Surf remains in full-screen mode. |
| Text Scaling | Enter a percentage value from 50 to 200 to set the text size in the app. Tip: On Android devices, you can also send a script to
									change the zoom level in the SOTI Surf
									app:  sendinfo net.soti.action.surf BROWSERZOOMLEVEL
											400where 400 is a
									percentage value. |
| Restore Tabs on Startup | When enabled, tabs from an earlier session are automatically loaded the next time you launch the SOTI Surf app. |
| Open Links in New Tab | When enabled, links open in a new tab instead of the current tab. |
| Open Files Automatically after Downloading | When enabled, files downloaded by the device user are automatically opened by the applicable app. |
| URL Suggestion | When enabled, SOTI Surf suggests websites as the device user types in the address bar. |
| Download Location | The device location where SOTI Surf saves files downloaded
								from the internet. This option only applies to files downloaded from
								sites that are not routed through ERG. Downloads from sites routed
								through ERG get saved in an application sandbox. The download
									location must be a location in the device's internal storage,
									for example, %sdcard% or a defined
									directory path. Directory paths can not begin or end with
										 Note: To save downloads to the
									root level, leave the download location field blank. If a device has many profiles with conflicting download location settings, it uses settings from the profile created first. |
| Hide Reset Settings | When enabled, device users can not see or access the Reset Settings option in the SOTI Surf app. |
| Open Same Link in Same Tab | Enable the device user to open the same link in the same tab if the link is already open. |
| Set User Agent | Select the User Agent used by SOTI Surf to access web
								applications. Use this feature when your devices can not accurately
								render certain web page applications by SOTI Surf. You can choose from:
| Browsing on Cellular | When enabled, the SOTI Surf app can use cellular networks. |
| Roaming | When enabled, the SOTI Surf app can use cellular networks while roaming. |
| WiFi | When enabled, the SOTI Surf app can use WiFi networks. |
| Enable Certificate Authentication | Option to map the certificate to a domain for automatic authentication in the SOTI Surf application. |
| Export Browsing History | Enable this option and then, in the File Location field, enter
								a folder location on the device's internal storage where you want to
								store SOTI Surf app's browser history. If a device has many profiles with conflicting file location settings, it uses settings from the profile created first. |
| Use Log In | When enabled, select from LDAP or IDP.
 Specify the user inactivity time (in minutes), before the user gets logged out. Enter 0 to enable inactivity timeout for the browser. After the profile is successfully assigned to a device, the following scenarios could happen:
| Delay Application Update | Specify the time (in minutes) between when a configuration change gets pushed to the
								device and when the app must shut down and apply the update. If this
								happens, device users must log in again. The device automatically
								relaunches after the update finishes. If a device gets assigned many SOTI Surf configurations with conflicting app shutdown times, the first configuration created applies. |
| Open New Tab in Background | When enabled, when a device user selects a link to open it in a new tab, the new tab
								always opens in the background. Note: If a device has many assigned
									profiles but has conflicting tab opening settings, the setting
									of the profile created first applies. |
| Allow Zoom Gestures | When enabled, device users can use gestures to zoom in and out in web pages. |
| Set Browser Zoom Level | Set the default magnification for all websites displayed in the SOTI Surf browser. You can set the zoom level to be between 50 and 500 percent. 100 percent is the standard zoom level. |
| Allow Media Auto-play | Disabling this feature prevents videos and audio clips from automatically starting playback. Muted videos are still autoplayed. |
| Hide Address Bar | Enabling this option hides the address bar in the SOTI Surf browser. This prevents device users from manually entering or editing website URLs, restricting user access to websites in the Home screen catalog. |
| Allow Pull to Refresh | Enabling this option lets the user refresh the web page using the pulldown gesture. |
| Auto-Refresh | Enabling this option refreshes the web page automatically according to the defined frequency. |
| Refresh Interval | Define the autorefresh interval for web pages. |
| Search Engine | Select a default search engine for SOTI Surf to run any searches from the address bar. If a device assigned to more than one profile has conflicting settings, the search engine from the first assigned profile applies. |
| Mixed Content | Select Always Allow to let both HTTP and HTTPS content load
								when displaying a web page. If you select Compatibility
									Mode, Android WebView enables some insecure content
								types while possibly blocking other types. If you assign more than one profile to a device, each having a different mixed content setting, SOTI Surf uses the profile with the earliest creation date. For example, profile A, created first, has a mixed content value of Never Allow. Profile B has the value configured as Compatibility Mode. The device follows Never Allow, as profile A is the earliest. |
| Allow Debugging | When enabled, users can debug web pages displayed in SOTI Surf. For more information on this process, see Debugging web sites and web apps in SOTI Surf on Android Devices. If you assign more than one profile to a device, each having a different allow debugging setting, SOTI Surf uses the profile with the earliest creation date. For example, profile A, created first, has allow debugging enabled. Profile B has allow debugging disabled. The device allow debugging as profile A is the earliest. |
| ProGlove Integration | Enable to integrate ProGlove wearable scanners with SOTI Surf. See Integrating ProGlove Scanners with SOTI Surf for more information. |
Privacy
The privacy settings section for the SOTI Surf profile configuration enables you to dictate the browsing capabilities of your device users.
If you assign more than one profile with differing SOTI Surf configurations to the same device, the most restrictive version of the setting applies. In general, settings enabled in the Privacy section are more restrictive with some noted exceptions.
| Allow Copy from Browser | When enabled, device users can copy content from within a browser - both to other web
								pages and to apps outside of the browser. Note: Enabling this option
									also enables Allow Screen Capture when
										Browsing and Allow Sharing of
										Downloaded Files. Both options can be enabled
									without also disabling Allow Copy from
										Browser. |
| Allow Screen Capture when Browsing | When enabled, device users can take screenshots of their device screen while SOTI Surf is the active app. |
| Allow Downloading of Files | When enabled, device users can download any files from within the SOTI Surf app. Note: Enabling this option also
									enables the Allow Sharing of Downloaded
										Files setting. However, you can deselect this
									option independently of Allow Downloading of
										Files. |
| Allow Sharing of Downloaded Files | When enabled, device users can share any files they have downloaded in SOTI Surf with another person or another app. |
| Restrict File Types | Enter file extensions for the file types that you want to block device users from
								downloading. Separate file extensions with a comma. For example:
| Preview Files | When enabled, device users can preview files before downloading them. |
| Allow Printing | When enabled, device users can print any content from within the browser. Note: Allow
									Printing does not allow cloud printing on sites such as Gmail,
									where printing options are available. |
| Allow JavaScript | When disabled, JavaScript does not run on any web pages. Note: Device users may
									experience significant limitations when navigating the internet
									due to the prevalence of JavaScript. |
| Allow Popups | When disabled, SOTI Surf prevents websites from opening any popup windows. Websites permit the use of alerts or confirmation boxes but block other websites from calling new web pages. |
| Allow Cookies | When disabled, websites cannot store any cookies on SOTI Surf. |
| Clear Cookies on Launch | When enabled, when a browser relaunches, SOTI Surf clears cookies from the earlier browser session. Note: You can enable Clear Cookies on Launch
									independently of Allow Cookies. |
| Allow Third Party Cookies | When disabled, SOTI Surf blocks cookies from third-party domains (cookies from domains beyond the site the user is currently visiting). |
| Allow Website Cache | When disabled, the browser does not cache website data when the app closes or the user navigates away from a web page. |
| Allow Auto Fill | When disabled, web pages with forms or fillable fields no longer retain any previously entered information. |
| Allow Safe Search | When disabled, SOTI Surf turns off the safe search filter
								(that is normally active on SOTI Surf) to
								block inappropriate/explicit images and videos. Device users can
								access all web content - if it is not blocked by other web filtering
								settings. Allow Safe Search applies to search results only. Note: When checked, Allow Safe Search is more
									restrictive. |
| Allow Access to Websites with Invalid SSL Certificate | When disabled, device users cannot access websites with SSL security certificate errors. |
| Allow Invalid SSL Certificate Warnings | When disabled, warnings about invalid SSL certificates are not shown to device users. Warning: This may lead to data security
									issues. You cannot use this option if you turned off Allow Access to Websites with invalid SSL certificate. |
| Clear History on Launch | When enabled, SOTI Surf clears browsing history from earlier
								sessions when you launch the SOTI Surf app. Note: If a device has  more than one profile with conflicting
									Clear History on Launch settings, the profile with the setting
									enabled takes precedence. |
| Allow Bookmarks | When disabled, device users cannot save webpages as new bookmarks or edit existing
								bookmarks in the SOTI Surf app. Note: If a
									device has more than one profile with conflicting Allow
									Bookmarks settings, the profile with the setting disabled takes
									precedence. |
| Open Files in Third Party Applications | When enabled, device users can open SOTI Surf-editor-unsupported files with third-party applications instead. Open Files in Third Party Applications is more restrictive when disabled. Devices with conflicting settings use the disabled setting and block the opening of files in third-party applications. |
Filtering
Intranet Gateway Settings
Use this dialog box to set up an Enterprise Resource Gateway (ERG) for SOTI Surf. ERG routes your web traffic through a proxy server and grants device users access to your internal network. You must have ERG configured on a proxy server to use this feature. Once you have set up ERG, you can link your server to the SOTI Surf app through the SOTI Surf configuration.
Turn on Enable Intranet Gateway Settings and enter your ERG proxy address as an IP address/FQDN and its port number in the Enterprise Resource Gateway fields.
To specify which domains you want to route through the ERG, select Add in the Add a Domain table to add a new row.
Select Import to upload a .csv or .txt file with a list of domains to SOTI MobiControl.
To delete a domain, hover over its row and select Delete.
Website Restrictions
You can block users from accessing websites based on specific URLs or by website content. You can create a blocklist, an allowlist, or block websites based on content type.
When you apply a blocklist, any site on the blocklist redirects the device user to the default URL of blocked websites or a blank page, depending on your settings.
An allowlist is more restrictive than a blocklist. The device user can only access the sites specified on the allowlist. When the device user accesses any non-allowlisted sites, SOTI Surf redirects the device user to the default URL or a blank page, depending on your settings. Redirect URLs are automatically allowlisted.
You can not apply both a blocklist and an allowlist within the same profile configuration. If a device receives a blocklist and an allowlist from two different profiles, the allowlist overrides the blocklist. If a device receives more than one blocklist or more than one allowlists from different profiles, then SOTI Surf combines all the websites (and the exceptions) from the profiles.
Turn on Enable Website Restrictions and select a type: Blocklist or Allowlist.
To specify which websites you want to filter, select Add in the Websites table to add a new row.
To delete an entry, hover over its row and select Delete.
In the Redirection URL for Blocked Websites/Categories, enter a website URL. When device users try to access an unauthorized website, they are automatically redirected to the entered URL.
Turn on Exclude websites from the filter and select Add in the Websites table to add a new website exception to your blocklist or allowlist.
You can add an exception to web content categories by adding the website to the exception list of an Allowlist web filter.
Devices with blocked categories from many profiles receive all the categories from all applied profiles.
Kiosk Mode
Kiosk mode limits SOTI Surf functionality, reducing device users' access to websites and SOTI Surf app settings. This mode disables the address bar, and users can only navigate forward through hyperlinks and backward using the back button. The long-press context menu is also disabled.
If you assign more than one kiosk mode setting to a device, the most restrictive one applies.
| Hide App Bottom Bar | When enabled, device users cannot access the bottom bar of the SOTI Surf app. The bottom bar includes the
								forward and backward navigation buttons, plus the home and the app
								menu icons. Selecting this option causes the Hide App Menu and Clear Cookies with Home options to become automatically selected. |
| Hide App Menu | When enabled, device users cannot access the app menu. |
| Clear Cookies with Home | When enabled, whenever the device user navigates to the home screen, SOTI Surf clears browser cookies. Note: This
									option is redundant if you select Allow
										Cookies in the Configure Privacy
										Settings section. |
| Allow Multiple Tabs | When enabled, the device user can access more than one tab in kiosk mode. |
| Allow Keyboard | When disabled, device users cannot display the keyboard. For example, when they tap on
								a text field. Note: Device users can still use the keyboard to log
									in, after which it becomes disabled. |
