VPN: NetMotion
The NetMotion VPN profile configuration enables you to configure NetMotion VPN settings for devices when:
| VPN Name | Enter a name for this VPN connection. The name cannot contain spaces or special characters. |
| VPN Server Hostname / IP Address | Enter the hostname or IP address for your VPN server. |
| Username | Enter a username.
								 You can use the following macros to specify usernames:   |
| Domain | Enter the domain that authenticates your VPN connection |
Authentication
| Authentication Type | Select the authentication method that this VPN connection uses. |
| Password | Enter a password that authenticates the connection on the devices. |
| Identity Certificate | Select the identity certificate used to authenticate with the VPN server. |
