Device Functionality
Features
| Feature | Description | Profile |
| Allow Camera | When enabled, the device user can use the camera.  Note: If
										camera. Important: This feature is available and applies to Android devices OS
										6.0 or later.  |
								W |
| Allow Screen Capture | When enabled, device users can save images or recordings of the display. | W |
| Allow Factory Reset | When enabled, device users can erase all applications,
									settings, and data from the phone's internal storage. Restriction: Not supported for AMAPI-enrolled
										devices.  |
									 P, W Restriction: Not available on Android 11 COPE
											devices.
| Allow Safe Boot | When enabled, you can reboot devices into safe boot mode.
									However, SOTI MobiControl disables third-party
									software in a safe boot.  Important: This feature is available and applies
										to Android devices OS 6.0 or later. Restriction: Not supported for AMAPI-enrolled
										devices.  |
								P, W |
									within safe places that the device user can define.  Note: If you enable Allow All
								P, W |
| Allow SMS | When enabled, the device can send and receive SMS. | P, W |
| Stay Awake while Charging | Determines who controls if the device remains
									awake while charging.
										devices.  |
								P, W |
| Allow Keyguard Camera | When enabled, the device user can launch the camera
									app from the lock screen.  If you enable Allow All Keyguard Features, Allow Keyguard Camera is automatically enabled too.  |
								P, W |
| Allow Printing for Work Profile | When enabled, device users can use the device's printing
									capabilities.  Important: This
										feature is available and applies to Android devices OS 9.0
										AMAPI-enrolled devices.  |
								W |
| Allow Outgoing Cellular Phone Calls | When enabled, device users can not perform outbound calls. Internet or Voice-over-IP (VoIP) are not blocked. | P, W |
									 When enabled, when a supported app launches for the first time, it skips any introductory hints or tutorials. Note: Not available on Android 11 COPE
											devices.
											devices.
								P, W |
| Location Accuracy | Determines the accuracy of the location reporting data
									and who controls that accuracy.
										devices.  |
								P, W |
| Allow Date Time Management | When enabled, device users can configure the
									device's date, time, and timezone settings.  Important: This feature is
										available and applies to Android devices OS 9.0 or
										later.  |
								P, W |
| Allow Screen Timeout Management | When enabled, device users can configure
									screen timeout settings.  Important: This feature is available and applies
										to Android devices OS 9.0 or later. Note: Not
										available on Android 11 COPE devices. Restriction: Not supported for AMAPI-enrolled
										devices.  |
								P, W |
| Allow Brightness Configuration Management | When enabled, device users can configure
									brightness settings.  Important: This feature is available and applies
										devices.  |
								P, W |
| Allow Location Sharing for Work Profile | When enabled, you can enable location sharing for all managed profile apps. Apps running in the Work profile are unable to use device location information. | W |
Connectivity
Network Connections
| Allow Tethering Management | When enabled, device users can configure their
									device's tethering (sharing a mobile device's data connection
									with another device) settings.  Available on Managed Device only.  |
								P, W |
| Allow Bluetooth Management | When enabled, device users can configure their
									Bluetooth settings.  Available on Managed Device only.  |
								P, W |
| Allow Wi-Fi Management | When enabled, device users can configure Wi-Fi
									configurations.  Available on Managed Device only.
								P, W |
| Allow VPN Management | When enabled, device users can configure their VPN
									 P, W Note: Not available on Android 11 COPE devices.  |
| Allow Network Settings Reset | When enabled, device users can reset their
									network configurations from their settings.  Important: This feature is
										available and applies to Android devices OS 6.0 or
										later. Available on Managed Device only. Note: Not supported for AMAPI-enrolled
										devices.  |
| Minimum Wi-Fi Security Level | Set the minimum Wi-Fi security level that the
									device can connect to. For example, if you set the minimum Wi-Fi
									security level to WPA, the device can not connect to a WEP
										network. Available on Managed Device only.  |
								P, W |
| Data Roaming | Determines who controls the data roaming settings on the
									device.
								P, W |
| Bluetooth | Determines who has control over the Bluetooth setting.
								P, W |
| Wi-Fi | Determines who controls the Wi-Fi connection.
 Available on Managed Devices only Note: Not
										supported for AMAPI-enrolled devices.  |
								P, W |
Security Options
| Allow All Keyguard Features | When enabled, device users can use keyguard features on the lock screen. Keyguard features include fingerprint authentication, notification viewing, smart lock, and camera access. Enabling Allow All Keyguard Features automatically enables other keyguard options. | P, W |
									devices.  If you enable the Allow All Keyguard Features feature control option, Allow Fingerprint Authentication automatically enables too. Important: This feature is available and applies
										to Android devices OS 6.0 or later.  |
								P, W |
| Allow All Keyguard Notifications | When enabled, all notifications on secure
									lock screens are visible.  If you enable the Allow All Keyguard Features feature control option, Allow All Notifications automatically enables too.  |
								P, W |
| Allow Account Creation For Personal | Specify whether device users can add new personal accounts to the device. Select an
									option from the list:
 This does not remove any existing accounts from the device. SOTI MobiControl selects All by default.  |
								P |
| Allow Account Creation For Work | Specify whether device users can add new work accounts to the device. Select an
								W |
									optimization.  Note: Disabling this option negates any battery
										power to stay connected.  Note: Not supported for
								P, W |
									VPN.  Enter the package name of the VPN app.  |
								P, W |
| Allow All System UI | When enabled, system UI alerts appear to device users.
									This includes toast messages, phone activities (including
									priority), system alerts, system errors, and system
										overlays. Available on Managed Devices only. Note: Not
								P, W |
| Allow Verify Apps Enforcement | When enabled, the device user can change the Scan device for security threats option within the Google Play Store's Play Protect settings. | P, W |
| Play Integrity Attestation Frequency | When enabled, the device performs the SafetyNet check at every device check in, in addition to once daily. | P, W |
| Allow Copy/Paste between Work and Personal | When enabled, device users can copy text or images between the Work and Personal profiles. | W |
									secure lock screens.  If you enable Allow All Keyguard Features feature control option, Allow Sensitive Notifications automatically enables too. Important: This feature is available and applies
								P, W |
| Allow Uninstallation of Managed Applications | When enabled, device users can uninstall any managed applications. | W |
| Allow Third Party Input Methods | When enabled, device users can enable third-party input methods such as keyboards on their devices. | P, W |
| Allow Caller ID Information for Work Profile Contacts | When enabled, device users can see Caller ID information for calls from contacts saved within the Work profile. | W |
| Allow Installation from Unknown Sources | When enabled, device users can install apps other than those from the Google Play store. | W |
| Allow Installation from Unknown Sources on Personal | When enabled, device users
									can install apps that are not from the Google Play store on the
									personal profile of the device.  Important: This feature is available and applies
										to Android devices OS 10.0 or later.  |
								P |
| Allow Sharing from Work Profile to Personal | When enabled, device users can use
									an app's share function to share between apps on the Work
									profile and apps on the personal profile.  Important: This feature is available and applies
										to Android devices OS 5.1.1 or later.  |
								W |
									(only applies to apps in the Work Profile).  Note: For
										profile and not for the Personal profile.  |
								W |
| USB Debugging | Determines who controls the device's ability to enter USB
									Debugging mode.
								P, W |
| Allow USB File Transfer and USB Storage | When enabled, device users can transfer data
											 SOTI MobiControl enables this option by default. Note: AMAPI-enrolled devices have
										deprecated the  usbMassStorageEnabled
										property. |
								P, W |
| Allow Bluetooth Contact Sharing | When enabled, device users can use
									Bluetooth to share contact information.  Important: This feature is available and applies
								P, W |
										devices.  |
								P, W |
Policy Messaging
Restriction Policy
This
