Device Functionality
Features
										camera. Important: This feature is available and applies to Android devices OS
										6.0 or later. |
| Allow Screen Capture | When enabled, device users can save images or recordings of the display. |
											Android devices OS 6.0 or later. |
									capabilities. Important: This
										feature is available and applies to Android devices OS 9.0
										or later. Restriction: Not supported for
										AMAPI-enrolled devices. |
| Allow Location Sharing for Work Profile | When enabled, you can enable location sharing for all managed profile apps. Apps running in the Work profile are unable to use device location information. |
| Allow Skip App First Use Hints | When enabled, when a supported app launches for the first time, it skips any introductory hints or tutorials. Note: Not available on Android 11 COPE
											devices. Restriction: Not supported for AMAPI-enrolled
											devices. |
| Allow All Keyguard Features | When enabled, device users can use keyguard features on the lock screen. Keyguard features include fingerprint authentication, notification viewing, smart lock, and camera access. Enabling Allow All Keyguard Features automatically enables other keyguard options. |
										to Android devices OS 6.0 or later. |
 This does not remove any existing accounts from the device. Note: For AMAPI-enrolled devices, No
											Accounts is the only option
										available. |
										power to stay connected.  Note: Not supported for
| Allow Verify Apps Enforcement | When enabled, the device user can change the Scan device for security threats option within the Google Play Store's Play Protect settings. |
| Play Integrity Attestation Frequency | When enabled, the device performs the SafetyNet check at every device check in, in addition to once daily. |
| Allow Copy/Paste between Work and Personal | When enabled, device users can copy text or images between the Work and Personal profiles. |
| Allow Caller ID Information for Work Profile Contacts | When enabled, device users can see Caller ID information for calls from contacts saved within the Work profile. |
| Allow Installation from Unknown Sources | When enabled, device users can install apps other than those from the Google Play store. |
| Allow Installation from Unknown Sources on Personal | When enabled, device users
									can install apps that are not from the Google Play store on the
									personal profile of the device. Important: This feature is available and applies
										to Android devices OS 10.0 or later. |
| Allow Sharing from Work Profile to Personal | When enabled, device users can use
									an app's share function to share between apps on the Work
									profile and apps on the personal profile. Important: This feature is available and applies
										to Android devices OS 5.1.1 or later. |
| Allow Bluetooth Contact Sharing | When enabled, device users can use
									Bluetooth to share contact information. Important: This feature is available and applies
										devices. |
Policy Messaging
Restriction Policy
This
Work Profile Wipe Message
Enter the message that should appear to device users when the device wipes all Android Work Profile data and deletes the Android Work Profile.
