Authentication (Android Classic)
The Authentication configuration enables you to set minimum requirements for password-based user authentication on a device. You can apply this configuration when:
| Password | Enter an administrator password for the device that turns off security features such as Lockdown or Application Run Control. |
| Revert to User Mode | Enable this option to automatically switch from Administrator
									mode to User mode after a specified timeouttime. Use the slider
									to set the interval between 5 and 120 minutes, with a default
									setting of 30 minutes.
| Restrict Administrator Password Attempts | Restrict the number of password attempts a user can make for
									an administrator account before enforcing a lockout. Specify the
									number of wrong password attempts allowed before the account is
									temporarily locked. Set the duration of the account lockout once
									the user reaches the maximum number of password
											attempts.
Device User Password Policy
Turn on User Password Policy to set complexity requirements and other password policies for the device user.
Note: You must specify a device administrator password before you can configure a user password policy.
		Minimum Complexity
| Password Quality | Select the minimum password quality. Password quality options listed are in order of
								security strength, from least to most secure. Device users can use
								any password type option that is more secure than the selected
								minimum.
| Password/PIN Length | Set the minimum password or PIN length. |
| Complex Characters | Set the minimum number of complex (non-alphanumeric) characters required. |
History
| Maximum Password Age | Toggle on Maximum Password Age to enter the number of days before prompting a user to enter a new password. |
| Unique Passwords Before Reuse | Toggle on Unique Passwords Before Reuse to select the number of unique passwords a user must set before reusing an earlier password. |
Policy
| Screen Timeout | Toggle on Screen Timeout to set a maximum inactive time before the screen locks. |
| Device Authentication Wipe Policy | Toggle on Device Authentication Wipe Policy to set a maximum limit on entering incorrect passwords before a device is automatically wiped. |
| Common Access Card (CAC) Authentication | Select this option to use Common Access Card (CAC) authentication. |
