Wi-Fi (Android Classic)
General: Network
| Network Name | The name of the network to which the device should connect to. This is also the name of the wireless policy. |
| Set as Active Network | If toggled on, enables or restricts the device to connect to the
								Wi-Fi network automatically when you push the profile configuration
								to the agent for the first time. Note: Assigning a new Wi-Fi profile
									with Set as Active Network enabled replaces the existing
									Wi-Fi profile only if the Wi-Fi signal strength is 'Good' or
									higher. |
General: Security
| Security Type | The security protocol currently used on the network. You can
								select WEP, WPA/WPA2,
									802.1x Enterprise, or None. If you select the 802.1x Enterprise security protocol, the following configuration section appears:In the Protocols section, you can select TLS, LEAP, EAP-FAST, TTLS, and PEAP. In the Authentication section, you can set the following options: Restriction: 802.1x Wi-Fi is
									only supported on certain devices. Check Vendor Compatibility Matrix: 802.1x Enterprise WiFi for
									supported devices.
| Password | Enter the password required to connect to the network. |
| Proxy | SOTI MobiControl offers automatically or manually configurable proxies. When selecting Automatic, enter a URL in the URL field. When selecting Manual, enter data in the Proxy Server and Exceptions fields. |
| URL | If you select Automatic as the proxy setting, enter the proxy URL here. |
| Proxy Server | If you select Manual, enter the address, and (optionally) the port number, for the proxy server. |
| Exceptions | If you select Manual, enter any host exceptions that you want to connect directly to instead of through the proxy. Use commas to separate host exceptions. |
