Use the Feature Control profile configuration to disable device features such as the camera, microphone, USB access, and many more.
Device Functionality
Features
										camera. Important: This feature is available and applies to Android devices OS
										6.0 or later. |
| Allow Screen Capture | When enabled, device users can save images or recordings of the display. |
| Allow Factory Reset | When enabled, device users can erase all applications,
									settings, and data from the phone's internal storage. Restriction: Not supported for AMAPI-enrolled
										devices. |
| Allow Safe Boot | When enabled, you can reboot devices into safe boot mode.
									However, SOTI MobiControl disables third-party
									software in a safe boot. Important: This feature is available and applies
										to Android devices OS 6.0 or later. Restriction: Not supported for AMAPI-enrolled
										devices. |
											Android devices OS 6.0 or later. |
| Allow SMS | When enabled, the device can send and receive SMS. |
| Stay Awake while Charging | Determines who controls if the device remains
									awake while charging.
										devices. |
| Allow Status Bar | When enabled, you can expand the status bar to view
									device notifications details. Important: This feature is available and applies
										to Android devices OS 6.0 or later. |
| Allow Keyguard Camera | When enabled, the device user can launch the camera
| Allow Microphone | When enabled, the device user can use the microphone to record audio. |
| Allow Airplane Mode | When enabled, device users can turn on Airplane mode. Important: This feature is
										available and applies to Android devices OS 9.0 or
										later. |
| Allow Ambient Display | When enabled, device users can turn on Ambient
									Display. Important: This
										feature is available and applies to Android devices OS 9.0
										or later. |
| Allow Device Volume | When enabled, the volume settings are visible to and
									changeable by the device user. Important: This feature is available and applies
										to Android devices OS 9.0 or later. |
									capabilities. Important: This
										AMAPI-enrolled devices. |
| Allow Certificate Management | When enabled, device users can configure stored credentials (certificates) in the device's settings. |
| Allow App Management | When enabled, device users can configure or uninstall apps (and app data). This includes disabling the ability to force close an app, clear app data, app caches, and app default launch settings. |
| Allow Outgoing Cellular Phone Calls | When enabled, device users can not perform outbound calls. Internet or Voice-over-IP (VoIP) are not blocked. |
| Allow Skip App First Use Hints | When enabled, when a supported app launches for the first time, it skips any introductory hints or tutorials. Note: Not available on Android 11 COPE
											devices. Restriction: Not supported for AMAPI-enrolled
											devices. |
| Location Accuracy | Determines the accuracy of the location reporting data
									and who controls that accuracy.
										devices. |
| Allow Date Time Management | When enabled, device users can configure the
									device's date, time, and timezone settings. Important: This feature is
										later. |
| Allow Screen Timeout Management | When enabled, device users can configure
									screen timeout settings. Important: This feature is available and applies
										to Android devices OS 9.0 or later. Note: Not
										available on Android 11 COPE devices. Restriction: Not supported for AMAPI-enrolled
										devices. |
| Allow Brightness Configuration Management | When enabled, device users can configure
									brightness settings. Important: This feature is available and applies
										devices. |
Connectivity
Network Connections
| Allow Tethering Management | When enabled, device users can configure their
									device's tethering (sharing a mobile device's data connection
									with another device) settings. Available on Managed Device only. |
| Allow Bluetooth Management | When enabled, device users can configure their
									Bluetooth settings. Available on Managed Device only. |
| Allow Wi-Fi Management | When enabled, device users can configure Wi-Fi
									configurations. Available on Managed Device only.
| Allow VPN Management | When enabled, device users can configure their VPN
| Allow Network Settings Reset | When enabled, device users can reset their
									network configurations from their settings. Important: This feature is
										available and applies to Android devices OS 6.0 or
										later. Available on Managed Device only. Note: Not supported for AMAPI-enrolled
										devices. |
| Minimum Wi-Fi Security Level | Set the minimum Wi-Fi security level that the
									device can connect to. For example, if you set the minimum Wi-Fi
									security level to WPA, the device can not connect to a WEP
										network. Available on Managed Device only. |
| Data Roaming | Determines who controls the data roaming settings on the
									device.
| Bluetooth | Determines who has control over the Bluetooth setting.
| Wi-Fi | Determines who controls the Wi-Fi connection.
 Available on Managed Devices only Note: Not
Security Options
| Allow All Keyguard Features | When enabled, device users can use keyguard features on the lock screen. Keyguard features include fingerprint authentication, notification viewing, smart lock, and camera access. Enabling Allow All Keyguard Features automatically enables other keyguard options. |
| Allow All Keyguard Notifications | When enabled, all notifications on secure
 This does not remove any existing accounts from the device. Note: For AMAPI-enrolled devices, No
											Accounts is the only option
										available. |
										power to stay connected.  Note: Not supported for
| Allow All System UI | When enabled, system UI alerts appear to device users.
									This includes toast messages, phone activities (including
									priority), system alerts, system errors, and system
										overlays. Available on Managed Devices only. Note: Not
| Allow Verify Apps Enforcement | When enabled, the device user can change the Scan device for security threats option within the Google Play Store's Play Protect settings. |
| Play Integrity Attestation Frequency | When enabled, the device performs the SafetyNet check at every device check in, in addition to once daily. |
| Allow Caller ID Information for Work Profile Contacts | When enabled, device users can see Caller ID information for calls from contacts saved within the Work profile. |
| Allow Installation from Unknown Sources | When enabled, device users can install apps other than those from the Google Play store. |
| Allow Multi-User Control | When enabled, device users can add secondary users or remove added secondary users. |
| Allow Mounting Physical External Media | When enabled, device users can mount
									physical external media (including SD cards) to their devices. Note: This does not disable external media through the
										device's charging port. See Allow USB File
											Transfer and USB Storage.  |
| USB Debugging | Determines who controls the device's ability to enter USB
									Debugging mode.
| Allow USB File Transfer and USB Storage | When enabled, device users can transfer data
									using a USB connection or save to a USB storage device. SOTI MobiControl enables this option by default. Note: AMAPI-enrolled devices have
										deprecated the  usbMassStorageEnabledproperty. |
										devices. |
Policy Messaging
Restriction Policy
This
