Out of Contact
The Out of Contact configuration enables you to specify actions to be taken if a device fails to connect with SOTI MobiControl within a specified period of time. You do this when:
Note: This profile configuration is not supported for AMAPI-enrolled devices.
		Device Side Action
Select Add to configure a new event configuration that determines the actions that should occur if a device has not connected with SOTI MobiControl within the specified period. Select a script from the dropdown list to execute the configuration. To create scripts, see Manage Scripts.
You can add many event configurations.
To delete an event configuration, hover over the event configuration you want to remove and select the Delete icon that appears.
