Using Views in Live View
Use Views to create customized visualizations of your device fleet data. You can choose which topics to display, the target platform, the filters to apply and the flags you would like to configure for notification. Create views that shows only devices in a specific geographical area, devices with low battery levels, or devices running a particular app.
By creating different views, you can focus on specific aspects of your fleet. This helps you monitor critical data efficiently. For example, create one view for tracking speed, Wi-Fi or cellular signal, device drops, or custom data retrieved from your customer apps.
In the following sections, learn how to create a view, start it, save a live view session and load a saved session.
