Setting Up SOTI XSight
Open SOTI MobiControl from SOTI XSight
                    Select .
The SOTI MobiControl console opens in a new tab.
View Device Information for Devices Managed by SOTI MobiControl.
                    Select .
The Incident Management dashboard displays. -
                    Select an incident in the Incident Management dashboard.
The Incident Details view displays. -
                     In the Incident Details view, in the Devices
                        section, select a device.
If the device is managed by SOTI MobiControl 14.0 or later, the Device Information panel opens in the SOTI MobiControl console.
Setup and Change Various Configuration Settings
- To deploy the SOTI XSight agent, see Generate XSight Agent.
 - To synchronize information with SOTI MobiControl, see Generate XSight Agent.
 - To configure roles and permissions, see Roles and Permissions.
 - To configure various settings, see Settings.
 - To select the language, see Language.
