Live View Heatmap Data Reference
Legend Values for Heatmap Ranges
Signal Strength
| Type | Legend |
| 5G NR (SS-RSRP) |
| 4G/LTE (RSRP) |
| 3G (RSCP) |
| 3G (RSSI) |
| 2G (RSSI) |
Signal Quality
| Type | Legend |
| 5G NR SA (SS-RSRQ) |
| 4G/5G NSA (RSRQ) |
| 3G (ECNO) |
| 2G (RXQUAL) |
Signal-to-Noise Ratio
| Type | Legend |
| SINR for 4G/5G |
Network Type
| Type | Legend |
| 5G | Purple |
| 4G | Green |
| 3G | Blue |
| 2G | Orange |
Signal Dropouts
| Type | Legend |
| Minimal Impact | Dropout readings between 0-10 seconds |
| Moderate Impact | 11-30 seconds |
| High Impact | 31-60 seconds |
| Critical Impact | Over 60 seconds |
Signal Strength Data Collection
Collected Data
| Type | |
| 5G NR SA |
| 5G/4G NR NSA |
                                 Note: values in this category have 5G values
                                    separated from 4G values with a '/'. NSA has the phone connected
                                    to both 5G and 4G at the same time.
| 4G LTE/LTE+ |
| 3G UMTS/ HSPA+ |
| 2G GSM |
Android Signal Strength Parameters
The list of accessed parameters and data types with sample values for all technologies (2G GSM/3G/4G LTE/SG NR)
- RSSI (For 2G & 3G) in dBm
Data Type: INT, example: -24
 - Bands (RFCN for 2G&3G as its not operate on multiple frequencies)
Data Type: Array ff INT values, example: intArrayOf(1,3,7,20)
- Band 1 corresponds to the 2100 MHz band.
 - Band 3 corresponds to the 1800 MHz band.
 - Band 7 corresponds to the 2600 MHz band.
 - Band 20 corresponds to the 800 MHz band.
 - ASU level
Data Type: INT, example: 43
 - RSLEV, RSRP (receieved signal power or level) in dBm
Data Type: INT, example: -90 (-140 to -43)
 - RXQUAL, RSRQ (recieved signal quality)
Data TYpe: INT, example: 5 (from Oto 7)
 - MNC-3 digit number
Data Type: INT, example: 610
 - MCC-3 digit number
Data Type: INT, example: 302
 - LAC, eNodeB, gNodeB (local area code)
Data TYpe: LONG, example: 141218397
 - CID (network cell identity)
Data Type: LONG, example: 141218397
 - PCI (physical cell identity)
Data Type: INT, example: 290
SignalStrength Parameter Validation
- No value for 'band' for 2G and 3G
In GSM and WCDMA networks, the concept of "bands"as it exists in LTE and NR is not directly applicable. GSM and WCDMA networks operate on specific frequency bands allocated by regulatory bodies, but these bands are typically not exposed directly in the same way as in LTEand NR.
Instead,we have RFCN (Radio Frequency Channel Number)
- Not accessible: 5G- gNodeB
| Variable | Data Type | Parameter Range | Sample/Example Value |
| rssi/signal power | Numeric | 2G: -113 to - 51 dBm, 3G: -120 to - 24 dBm, 4G: -140 to - 43 dBm, 5G: -156 to - 31 dBm | -70dBm |
| Band | Text | [1,3,7,20] | 7 |
| SNR | Numeric | 2G (BER): 0 to 7, 3G: ECNO: 0 to 7, 4G: -20 to 30 dB, SG: -23 to 40 dB | 25dB |
| Signal Quality | Numeric | 2G: 0 to 7, 4G: not given (but somewhere around 5G's), 5G: -156 dBm to -31 dBm | 6 |
| MCC | Numeric | Numerical Number | 302 |
| MNC | Numeric | Numerical Number | 480 |
| ci/bsid | Text | Numerical Number | 123456 |
| CID | Numeric | Numerical Number | 12345 |
| PCI | Numeric | Numerical Number | 120 |
| DropCount min | Numeric | Minimum value: 0 | 0 |
Range of the above parameters
1. RSSI:
- 2G: -113 to-51 dBm
 - 3G: -120 to -24 dBm
 - 4G: -140 to -43 dBm
 - 5G: -156 to -31 dBm
2. Bands: [1,3, 7,20]
3. SNR:
- 2G (BER): 0 to 7
 - 3G: ECNO: 0 to 7
 - 4G: -20 to 30 dB
 - 5G: -23 to 40 dB
4. Signal Power:
5. Signal Quality:
- 2G: 0 to 7
 - 4G: not given (but somewhere around 5G's)
 - 5G: -156 dBm to -31 dBm
6. MNC & MCC: Numerical Number (For example: 302)
7. LAC, CID, PCI: Numerical Number
Sample Data From 4G (LTE):
Cellldentitylte:{ mCi=1******59 mPci=47 mTac=3***5 mEarfcn=66961 mBands=[66]
mBandwidth=2147483647 mMcc=302 m Mnc=490 mAlphalong=Freedom mAlphaShort=HOME
mAdditionalPlmns={} mCsglnfo=null}
CellSignalStrengthlte: rssi=-67 rsrp=-120 rsrq=-13 rssnr=2 cqiTablelndex=2147483647 cqi=6 ta=18 level=O
parametersUseForlevel=O
            Sample Data From 3G (WCDMA):
CellldentityWcdma:{ mlac=1 ***2 mCid=2******19 mPsc=299 mUarfcn=487 mMcc=302 mMnc=610
mAlphalong=Bell mAlphaShort=Bell mAdditionalPlmns={} mCsglnfo=null}
CellSignalStrengthWcdma: ss=-63 ber=O rscp=-24 ecno=O level=4
