Example: Setting up and Using a Gridview Layout
To try the example below, you must have done the following:
The following example shows how to set up a Gridview layout to dynamically change its content when the user selects a button or image. The Gridview layout works with a widget's On Click event.
  1. From the app page, select the Business Card button. The Button Properties tab opens.
  2. Select the Events tab.
  3. From Events, select On Click.
  4. From Actions, select Add. A list of actions opens.
  5. From the list, select Display Page in a Window. The configuration options for the action display and numbers for each grid section appear.
    Configuration options for the action
    The purpose of configuring this action is to replace the content in a section of the Gridview with content from another page when the user selects the Business Card button.
  6. From Display in Window, select the Gridview section number of the form where the new content goes.
  7. From Page to Display, select the page to display.
  8. Select Add.
  9. Repeat steps 1 to 8 for the QR Code button.
  10. Select Save in the SOTI Snap banner to apply your changes.
    Save app button
You have completed the Gridview layout example and can dynamically change its content through user interaction.
Tip: Select Preview to see the user's experience of how the Gridview layout behaves in your app.
