Adding Phone Calls
Use this configuration to add or edit phone call restrictions when doing the following actions:
Name Enter a descriptive name you want to give this list of phone numbers.
Call Direction Select the phone call direction you want to allow or deny for this list of phone numbers: incoming, outgoing, or both.
Call Type Select whether you want to allow or deny access to this list of phone numbers.
Add Phone Numbers Enter a phone number per row. Click Add to add a new row. You can also import a .txt file with a list of phone numbers. The imported file must have the following format:
  • The file must be in plain text format
  • The file must have one phone number per line
  • The file must have no more than 2000 lines
Note: The phone number must contain only numbers. Do not include number group separators such as dashes or spaces.
Using Wildcard Characters
SOTI MobiControl supports the use of the asterisk (*) and question mark (?) wildcard characters to indicate a range of phone numbers. An asterisk matches zero or more digits and a question mark matches one digit.
    4445551230
    4445551231
    4445551232
    4445551233
    4445551234
    4445551235
    4445551236
    4445551237
    4445551238
    4445551239
You can also use the two wildcard characters in combination. For example, 4??55512* matches 4325551234, but does not match 4324321234.
