Blockly Reference
All blocks supported in SOTI Snap are available in the Toolbox on the left of the Blockly Editor. Select a Block category to open it and pull a block from that section. Hover over each block to see a tooltip that briefly describes its purpose.
Note: SOTI customized Blockly to blend seamlessly with the
SOTI Snap app building process. For a comprehensive
overview of Blockly in general, see the Google Blockly Reference Guide.
Tip: Use the search field in the Blockly Editor to quickly find blocks.
