Last Location Dashboard
This dashboard displays a map showing the last known location of devices.
To open the Last Location dashboard, select Last Location from the dropdown menu.
Select a time and date range from the menu to view device locations. Select a pin in the map to open the single device dashboard, listing devices associated with that point.
Connection Type
This chart shows a breakdown of devices based on different connection types of the devices.
How to use this chartUse this chart to identify last location based on whether the device connected via Wi-Fi, 5G, 4G, 3G, LTE or an unknown connection.
CalculationSOTI XSight identifies last location of the device based on the medium the device connects to.
Mobile Carriers
This chart shows a breakdown of devices based on mobile carriers used across devices.
How to use this chartUse this chart to identify last location of devices based on the mobile carrier of the device.
CalculationSOTI XSight identifies the last location of devices based on the connected mobile carriers.
Network SSIDs
This chart shows a breakdown of devices based on their network SSIDs.
How to use this chartUse this chart to identify the network SSID of devices when connected over Wi-Fi.
CalculationSOTI XSight identifies last location of the device based on their network SSIDs when connected over Wi-Fi.
Carrier Signal Strength
This chart shows a breakdown of devices based on carrier signal strength.
How to use this chartUse this chart to identify the signal strength of devices based on their carrier signal strength.
CalculationSOTI XSight identifies last location of devices based on the carrier’s signal strength.
