Smart Battery Dashboards and Pools
Analyzing Smart Battery Condition
Smart battery analysis provides you with extensive data. You can view and analyze
your battery data to get the most out of your battery fleet. Use the Smart Battery
Dashboards to analyze the performance of swappable batteries or smart batteries
embedded in devices, track their usage, and estimate the appropriate time to replace
them.
Note: Batteries are tracked by serial number.
Note: To analyze battery usage from the
perspective of the device, select Smart Battery Dashboards and
Pools on the Devices tab.
Note: See Supported Batteries for a list of
supported smart batteries.
