Live View
Live View gives you visibility into a limitless range of business-critical intelligence collected from your fleet of mobile devices. With Live View, you can gain a deeper understanding of your operations, reduce downtime, diagnose problems and even solve them before they happen.
Live View collects real-time data recorded by your device fleet, at a collection frequency you select, then displays it as a map or a list. You can select any device and drill down to see all the data and events collected during the view session. What's more, Live View includes a time slice tool that lets you see device activity at any point up to two hours prior.
| Method | Description |
| SOTI Snap | Automatic integration of custom apps created using SOTI Snap. |
| XT Sock Smart Battery Plugin | Integration of smart battery analytics using the XT Sock Smart Battery Plugin. |
| JSON file | Integration of third-party app data using JSON files. |
Live View supports both Android and Windows Modern platforms, and is compatible with any version of SOTI MobiControl.
To get started using Live View, see the following topics:
