Managing Shared Topics
Add shared topics to views when creating a view. Shared topics provides the following
capabilities:
Accessing Managed Shared Topics
From the main menu, select Live View. The Live View map
displays.
In the Live View Map display, from the main menu, select Manage
Shared Topics.
Creating a Shared Topic
In the Manage Shared Topics window, select the Add
Shared Topic icon.
In the Shared Topic Configuration panel, enter the
following:
- A Name for the configuration.
- The MobiControl Instance.
- The Platform for the device groups.
- In the Group Filter section, select the device groups to add.
Add topics to monitor
In the Topics to Monitor section, select the Add
Shared Topic icon.
In the Add Shared Topic Wizard panel, select
Next.
Choose the type of values to retrieve for this topic (see Adding Custom Topics for more information on value
types).
- Select Next.
Select the Collection Frequency, Significant
Change and Units for the custom topic
you are creating. .
Note: Collection Frequency sets how often the device sends topic data. Significant Change tells the device to send data when this condition occurs, regardless of the collection frequency.
- Select Next
Choose how to retrieve values from a third part application and select
Next.
- If you select Retrieve data from SOTI Snap App (Android
only), you must specify the parameters needed to
retrieve data using the XT Sock interface for SOTI Snap.Enter the following:Note: See Adding Custom Topics for more information on the XT Sock interface.
- The Display Prompt Text.
- The Topic Identifier used in SOTI Snap.
- Select the Show error if app cannot be read from checkbox if you want an error to display if the application cannot be read from.
- If you select Use XT Sock Interface, you must
specify the parameters needed to retrieve data using the XT Sock
interface. Enter the following:
- The Package/Prog Id.
- The application Signature.
- The XT Sock Field Key.
- If you select retrieve data from JSON file you need to specify the
parameters needed to retrieve data from a JSON file on the
device{color} . Enter the following:
- The File Path required to retrieve the JSON file.
- The JSONPath needed to retrieve the data
- Select Finish.
When you have all the topics you want, select
Save.
Editing a Shared Topic
In the Manage Shared Topics window, hover over the
shared topic to edit and select Edit.
Edit the details of the shared topic in the Shared Topic
Configuration panel.
- Select Save.
Deleting a Shared Topic
shared topic to delete and select
Delete.
Select Yes.
