Loading a Saved Live View Session
This topic shows how to view a saved Live View session.
To load a saved Live View session:
  1. Make sure that a view is not currently started.
  2. From the Saved Sessions dropdown list, select a saved session to view.
    The Saved Sessions dropdown menu showing a saved session
  3. Select Start. The saved view displays.
  4. Select Stop to stop the live view.
    Note: You can use the Time Slice tool to view up to two hours of past activity for the saved view.
