Using Views in Live View
Use Views to create customized visualizations of your device fleet data. You can choose which information to display, how it’s presented, and what filters to apply. Create views that shows only devices in a specific geographical area, devices with low battery levels, or devices running a particular app.
By creating different views, you can focus on specific aspects of your fleet. This helps you monitor critical data efficiently. For example, create one view for tracking device locations on a map and another view for monitoring battery levels.
In the following sections, learn how to create a view, start it, save a live view session and load a saved session.
