Editing an Indoor Location
This topic describes how to edit Indoor Location details.
You can edit the following configuration details:
  • Building Name
  • Indoor Location Name
  • Description
  • Floor Level
  • Default Floor
  • Data provider and Image
  • Geolocation of the indoor map
You cannot edit the following configuration details:
  • Address, Latitude, and Longitude: Once a building is saved, its associated Azure address cannot be changed. You must manually delete and configure the building again.
  • Connection Type (Data Provider and GPS): Once a location is saved, its associated Connection Type cannot be changed. You must manually delete and configure the location again.
Note: Changing the Building name changes it for all indoor locations associated with it.
Note: Building name, Indoor Location name, and Floor Level must be unique.
Note: In a building, there can only be one indoor location marked as the Default Floor. Marking a new indoor location to be the default floor resets the previously default floor.
Note: If you incorrectly configure the Address (or Latitude and Longitude), you must delete the wrongly configured indoor locations and create new ones with the correct Address (or Latitude and Longitude).
Note: When configuring a connection, you cannot configure a data provider floor twice. Indoor Location and Data Provider floor have a one-to-one relationship.
