Editing a Data Provider
The following steps describe how to navigate to the Live View Data
                    Provider panel and select a data provider to edit.
                Select Live View from the main menu.
                Select Manage Locations from the main menu.
 - In the Manage Indoor Locations panel, select Data Providers.
                Hover over the entry of the data provider you wish to edit and right-click. In
                    the pop-up menu select Edit.
                In the Edit Data Provider panel, update the data provider
                    settings.
                Note: The data provider Name must be unique.
                Select Save And Copy Webhook URL to save your
                    changes.
                Note: You can regenerate the webhook details if required. Regenerated keys must be re-authorized in your data provider dashboard. Please see Adding a Data Provider for details on how to access your data provider dashboard and enter the values there.
