Renaming Groups
Rename groups that you have created.
Note: Renaming a group affects all
incidents associated with the group.
To rename a group:
- From the main menu, select
Select on the left of
the group name you wish to rename (see blue box below).
- In the pop-up menu, select Rename (see red box above).
In the Rename Group panel, enter a Group Name and
Group Prefix.
- Select Save.
