Wi-Fi
The Wi-Fi dashboard displays information such as Wi-Fi signal strength, network usage by device, access point usage, and device disconnects. See the Device Analysis Dashboards Overview section for information on Accessing and Customizing a Device Analysis Dashboard.
To open the Wi-Fi dashboard:
  1. Follow steps 1 through 4 in Accessing and Customizing a Device Analysis Dashboard.
  2. In the Dashboard dropdown, select Network/Data > Wi-Fi.
    Accessing the Wi-Fi dashboard
  3. Hover over data in a chart to see more detail. Select data in a chart to filter the other charts.
    • The bottom of the dashboard lists all devices in the selected analysis profile.
    • Selecting a segment or column in a chart refines the list.
    • Selecting any of the devices in the list opens the Device Spotlight view.
    • The view shows operational details of the selected device.
Wi-Fi dashboard overview
Wi-Fi Signal Strength
This chart categorizes Wi-Fi signal strength readings into different user-defined buckets, such as "Bad," "Average," and "Good." The chart segments the signal strength reading data, providing a visual representation of the proportion of readings that fall into each category.
Wi-Fi signal strength chart
Frequency Band
This chart maps Wi-Fi signal readings to different frequency bands (for example, 2.4 GHz, 5 GHz).
Wi-Fi frequency band chart
Average Wi-Fi Signal Strength
This chart displays the average Wi-Fi signal strength over time, measured in dBm. The x-axis represents time (for example, days, hours), and the y-axis shows the average signal strength.
Wi-Fi average signal strength chart
Average Time on Metered/Unmetered Connections
This chart shows the average time devices spend per day on metered and unmetered connections. The x-axis represents time (for example, days), and the y-axis shows the average time spent on each type of connection, ignoring null values but including 0 and capping at 24 hours.
Wi-Fi average time metered/unmetered connections chart
Devices on Metered/Unmetered Connections
This chart shows the number of devices connected to metered or unmetered connections over time. The x-axis represents time (for example, days, hours) and the y-axis represents the number of devices.
Wi-Fi devices metered/unmetered chart
Daily Average Time on Metered Connection
This chart shows which devices spend the most or least time on metered connections per day, ignoring null values, including 0 and capping at 24 hours in the average calculation. The y-axis represents individual devices, while the x-axis shows the average time spent on metered connections.
Wi-Fi daily average time on metered connection chart
Network Usage by Devices (SSID)
This chart shows the most or least Wi-Fi networks (SSIDs) used by the number of devices over time. The x-axis represents time (for example, days, hours), while the y-axis shows the number of devices connected to each SSID.
Wi-Fi network usage by devices
Access Point Usage by Devices (BSSID)
This chart shows the most or least Wi-Fi access points (BSSIDs) used by the number of devices over time. The x-axis represents time (for example, days, hours), and the y-axis shows the number of devices connected to each access point.
Wi-Fi access point usage by devices chart
Network (SSID)
This chart shows the most or least used Wi-Fi networks (SSIDs) by the number of devices. The x-axis represents different networks, while the y-axis shows the number of devices connected to each network.
Wi-Fi network chart
Access Points (BSSID)
This chart shows the most or least used Wi-Fi access points (BSSIDs) by the number of devices. The x-axis represents different access points, while the y-axis shows the number of devices connected to each access point.
Wi-Fi access points chart
Access Point–Disconnects
This chart shows the Wi-Fi access points (BSSIDs) with the most or least number of device disconnections. The x-axis represents different access points, while the y-axis shows the number of disconnections.
Wi-Fi access point disconnects
Device Disconnects
This chart shows the devices with the most or least number of disconnects from a Wi-Fi network. The y-axis represents individual devices, while the x-axis shows the number of disconnections.
Wi-Fi device disconnects chart
Number of Device Disconnects
This chart shows the number of device disconnects from the Wi-Fi network over time. The x-axis represents time (for example, days, hours) and the y-axis represents the number of disconnects.
Wi-Fi number of device disconnects chart
