Managing Shifts
Accessing Shifts
- Log into the SOTI XSight web console as administrator.
                    From the main menu, select Operational
                        Intelligence.
 - Open the main menu again.
                    Select Manage Shifts.
Accessing Shifts - Alternate Method
                        Intelligence.
                    From dashboard dropdown, select App Usage -
                        Shift.
                    Select Shift.
Creating a New Shift
- Use one of the methods above to access Manage Shifts,
                    In the Define a Shift panel, select the  icon.
                    In the Add a Shift panel, enter a
                            Name for the shift.
 - Select the Days of the week that correspond to the shift.
 - Select the shift hours for the shift.
 - Select Save.
Editing a Shift
- Access the Define a Shift panel. (See Accessing Shifts or Accessing Shifts - Alternate Method).
                    Hover over the row that has the shift you want to edit and select the  icon.
                    Select Edit.
                    Edit the shift information.
 - Select Save.
Deleting a Shift
                    Hover over the row that has the shift you want to delete and select the  icon.
                    Select Delete.
                    In the Delete Shift pop-up select
                            Confirm.
