| Enforce content cache | Enable this option to prevent the device user from disabling the
                                content cache on device. |
                        | Cached content type | Select the type of data that cached. All caches both shared and
                            iCloud content. |
                        | Use custom directory path for content cache | This option allows the admin to define the directory used for the
                                content cache. If kept disabled, it uses the default
                                location. |
                        | Custom directory path | This option appears when Use custom directory path for
                                    content cache is enabled. Define the custom path to
                                the directory used to store the content cache. |
                        | Default directory path | Define the default path to the directory used to store the content
                                cache. |
                        | Limit content cache disk space | This option allows the admin to limit the diskspace that can be used
                                by content cache. If kept disabled, the maximum available space is
                                used. |
                        | Cache size | This option appears when the Limit content disk
                                    space option is enabled. Define the maximum disk
                                space used for the content cache. |
                        | Auto-purge content cache | Automatically purge cache to free up disk space. Keep this disabled,
                                for optimal content caching performance. |
                        | Use custom port for content cache | The option allows the admin to define the port number used by content
                                cache. If kept disabled, a random port number is used. |
                        | Port number | This option appears when the Use custom port for content
                                    cache option is enabled. Define the custom port
                                number used by the content cache for uploads and downloads. |
                        | Log client details | Enable this option to log the IP addressess and port number of the
                                clients that request data from content cache. Important: If this option is
                                    enabled, identifiers related to enrolled/non-enrolled devices
                                    may be processed which may include personal
                                information. |
                        | Keep cache server awake | Enable this option to prevent the macOS device from entering into
                                sleep mode while hosting the content cache. |
                        | System notifications | Enable this option to display the system notifications for
                                exceptional conditions related to content caching. |
                        | Allow internet sharing | Switch off this toggle to deactivate internet sharing from the
                                content caching machine. |
                        | Automatically enable internet sharing | This option appears when the Allow internet
                                    sharing option is enabled. Enable this to prevent
                                users from disabling internet connection sharing. |
