Phone Calls > Restrictions > Phone Calls
Use this configuration to add or edit phone call restrictions when:
Name | Enter a descriptive name you want to give this list of phone numbers. |
Call Direction | Select the phone call direction you want to allow or deny for this list of phone numbers: incoming, outgoing, or both. |
Call Type | Select whether you want to allow or deny access to this list of phone numbers. |
Add Phone Numbers | Enter a phone number per row. Click Add to add a new row. You can also import a .txt file with a list of phone numbers. The imported file must
Note: The phone number must contain only numbers. Do not include number group separators such as dashes or spaces.
Using Wildcard Characters
SOTI MobiControl supports the use of the asterisk (*
) and question mark (?
) wildcard characters to indicate a range of phone numbers. An asterisk matches zero or more digits, and a question mark matches one digit.
Example: 416*
matches all phone numbers that start with 416.
Example: 444555123?
matches the following phone numbers:
4445551230
4445551231
4445551232
4445551233
4445551234
4445551235
4445551236
4445551237
4445551238
4445551239
You can also use the two wildcard characters in combination. For example, 4??55512*
would match 4325551234
, but not 4324321234
