Web Filter
Use the Web Filter configuration to specify what URLs you want to block or allow within the Google Chrome browser. You do this when:
If a URL is blocked, a device user will not be able to access that URL.
In the Add Website URL table, select Allow or Block as the Rule Type and then enter the URL for the website you want to allow or block. Click Add to add a new row to the table.
To remove a URL, hover over its table row and click Delete.
