VPN: F5 SSL
The F5 SSL VPN profile configuration enables you to configure F5 SSL VPN settings for devices when:
VPN Name Enter the name of the VPN connection
VPN Server Host Address Enter the server hostname or IP address of the VPN connection
Domain Enter the domain of the VPN connection
Username Enter the username for authenticating the connection. You can use macros such as %EnrolledUser_Upn%, %EnrolledUser_Domain%, or %EnrolledUser_Username% .
Authentication
Authentication Type Select the type of authentication used for this VPN connection. You can select Password or Certificate
Password If Password is selected, enter the password used for authentication
Identity Certificate If Certificate is used, select the certificate used for identity from the dropdown list.
Client Settings
FIPS-mode Select the check box to enable FIPS (Federal Information Processing Standard) 140-2.
