WiFi (Android Enterprise)
General: Network
Network Name The name of the network to which the device should connect. This is also the name of the Wireless Policy.
General: Security
Security Type Select the security protocol to use on the network. You can select WEP, WPA/WPA2, 802.1x Enterprise or None.
If you select the 802.1x Enterprise security protocol, the following configuration sections are displayed:
In the Protocols section, you can select TLS, LEAP, EAP-FAST, TTLS, and/or PEAP.
In the Authentication section, you can set the following options:
Username Enter the user name, or enter a macro used to set the user name.
Password Enter the password for the provided user name.
Use Identity Certificate Select a certificate used to connect to the wireless network.
Only certificates that have been uploaded to SOTI MobiControl appear in this list.
CA Certificate Select a CA certificate used to verify the wireless network connection.
Phase 2 Authentication Select the Phase 2 authentication protocol to use.
Anonymous Identity Enter an externally visible identification for the wireless connection (for TTLS, PEAP, and EAP-FAST only).
Password Enter a password to connect to the network.
Proxy Choose a proxy type:
  • Choose Automatic to enter a PAC URL used to receive proxy settings
  • Choose Manual to enter proxy settings manually
  • Choose None if you do not want to use a proxy for the WiFi connections
URL Enter a URL to the Proxy Auto-Configuration (PAC) file containing the proxy settings.
This option is only available if Automatic is selected as the Proxy type.
Proxy Server Enter the address, and (optionally) the port number, for the proxy server.
This option is only available if Manual is selected as the Proxy type.
Exceptions Enter any host exceptions that you want to connect directly to instead of through the proxy.
Use commas to separate host exceptions.
