IKE Version |
The IKE (Internet Key Exchange) version used for the VPN connection. |
Mobike |
Enable MOBIKE (IKEv2 Mobility and Multihoming Protocol) for the VPN account if IKE version 2 is selected. |
Authentication Type |
The type of authentication to be used. |
Pre-shared Key |
The pre-shared key for this VPN connection. |
IPSec User Certificate |
The user certificate used to authenticate against the IPSec VPN server. |
IPSec CA Certificate |
The CA certificate used to verify the IPSec VPN server. |
IKE Phase 1 Exchange Mode |
Select the IKE phase 1 exchange mode. |
Prefect Forward Secrecy |
Use prefect forward secrecy for authentication. |
IKE Identity |
The IPSec group ID type for the connection profile. |
Group Name |
The IPSec group ID type value for the connection profile. |
Suite B Type |
The Suite B type for the VPN connection. |
Diffie-Hellman Group |
The Diffie-Hellman group for the connection profile. |
Split Tunnel Type |
The Split Tunnel type for the VPN connection. |
Common Access Card Authentication |
Use Common Access Card (CAC) for authentication. |
