Email: IMAP Account
The IMAP Account email configuration enables you to configure IMAP account settings for your devices when:
Connection
Account Name | Specify Account Name or Description. |
IMAP Prefix | Specify IMAP Incoming Server Prefix. |
Email Notification | Choose what to do for email notification. |
Sync Interval | Frequency of synchronization. |
Signature | String to be used as the signature of the sender. |
Common Access Card Authentication | Use Common Access Card (CAC) for authentication. |
Incoming Server
Host Address | Enter the IP address or hostname, and (optionally) the port number, of the email server.
Security | Select the protocol used for mail data communication. |
User | Enter the user name. Supports the following macros: %EnrolledUser_Upn%, %EnrolledUser_Domain%, %EnrolledUser_Username%, %Prompt%. |
Authentication Type | Select the server authentication method. |
Password | Enter the password associated with the user entered above. |
Email Configuration | Enter email address for the device. E.g., bob.smith@mycompany.com. Supports the following macros: %EnrolledUser_Email%, %Prompt%. |
Outgoing Server
Host Address | Enter the IP Address or hostname, and (optionally) the port number, of the email server.
