APN
If a cellular service provider has given specific APN connection settings to allow devices to connect to the Internet, the APN profile configuration enables you to centrally manage these settings. You do this when:
Display Name | Enter a name for the APN that is displayed on the device. |
Access Point Name (APN) | Enter the name or web address of the access point provided by your wireless carrier. |
Mobile Country Code (MCC) | Select the three digit code, as defined by the ITU, that identifies the network's country of origin. |
Mobile Network Code (MNC) | Select the mobile network code. The list contains all available mobile networks in the selected country.
This option only appears after a Mobile Country Code is selected. |
Access Point Type | Select the access point type. |
Access Point Custom Type | Enter the custom access point type.
This option only appears if Any Type is selected as the Access Point Type. |
MVNO Type | Select the type of mobile virtual network operator (MVNO). |
MVNO Value | Enter a value for the mobile virtual network operator (MVNO).
This option only appears after a MVNO Type is selected. |
Default Connection | Select this option to make this the default APN connection for devices. |
Server
Access Point Connection Username | Enter the APN username provided by your wireless carrier. |
Access Point Connection Password | Enter the APN password provided by your wireless carrier. |
Host Address | Enter the hostname or IP address and port number of the server provided by your wireless carrier. |
Proxy Server Address | Enter the hostname or IP address of the proxy server. |
MMS Proxy Server Address | Enter the MMS proxy server address provided by your wireless carrier. |
MMS Server Address | Enter the MMS server address provided by your wireless carrier. |
Authentication Type | Select the type of authentication used for the APN connection. |
