WiFi (Android Classic)
General: Network
Network Name | The name of the network which the device should connect to. This is also the name of the Wireless Policy. |
General: Security
Security Type | The security protocol currently being used on the network. You can select WEP, WPA/WPA2, 802.1x Enterprise or None.
If you select the 802.1x Enterprise security protocol, the following configuration sections are displayed: In the Protocols section, you can select TLS, LEAP, EAP-FAST, TTLS, and/or PEAP. In the Authentication section, you can set the following options: Note: 802.1x WiFi is only supported on certain devices. Check Vendor Compatibility Matrix: 802.1x Enterprise WiFi for supported devices.
Password | Enter the password required to connect to the network. |
Proxy | SOTI MobiControl offers proxies to be automatically or manually configured. If Automatic is selected, enter a URL in the URL field. If Manual is selected, you must enter data in the Proxy Server and Exceptions fields. |
URL | If Automatic is selected as the proxy setting, enter the URL of the proxy here. |
Proxy Server | If Manual is selected, enter the address, and (optionally) the port number, for the proxy server. |
Exceptions | If Manual is selected, enter any host exceptions that you want to connect directly to instead of through the proxy.
Use commas to separate host exceptions. |
