Email: Exchange for Gmail
The Exchange for Gmail email configuration enables you to configure Microsoft Exchange ActiveSync settings for over-the-air synchronization of email. You perform this configuration when:
Connection
Account Name | Specify Account Name or Description. |
Username | Enter the user name. Supports Macros. (%EnrolledUser_Upn%, %EnrolledUser_Domain%, %EnrolledUser_Username%, %Prompt%) |
Hostname | Enter the IP address or hostname for the Exchange Server. |
Client Certificate | Select the client certificate. |
Email Address | Enter email address for the device. E.g., bob.smith@mycompany.com. Supports Macros. (%EnrolledUser_Email%, %Prompt%) |
Signature | Enter a string to be used as the signature of the sender. |
SSL Required | Enables and requires SSL on port numbers used with Hostname. (This setting is ignored when port 443 is used in Hostname). |
Accept All Certificates | Choose whether to accept all certificates sent by server. |
Default Sync Window | A value representing the time window for syncing with EAS (Exhange ActiveSync). |
