Per App VPN: F5 SSL
The F5 SSL Per App VPN feature allows you to select which apps must communicate over a VPN connection. You can also specify whether the per-app VPN will automatically start when the app initiates network communications. You do this when:
VPN Name Enter the name of the VPN connection.
VPN Server Host Address Enter the server hostname or IP address of the VPN connection.
Domain Enter the domain for authenticating the VPN connection.
Username Enter the username for authenticating the VPN connection. Supports macros.
Authentication
Authentication Type Select the type of authentication used for this VPN connection. You can select Password or Certificate.
Password If Password is selected as the authentication type, enter the password used for authentication.
Identity Certificate If Certificate is selected as the authentication type, select the certificate used for identity.
Note: For simplicity, you should deploy the certificate to your devices within the same profile as the per-app vpn configuration.
Client Settings
FIPS Mode Select this option to enable FIPS (Federal Information Processing Standard) 140-2.
Allow Application VPN Access Select this option to allow applications that are in the Managed Applications list to use the VPN server.
Click the Add button to enter an app name and search the App Store for the applications you want this VPN to apply to. If you have several apps for which you would like to use the VPN, you can upload a .csv or .txt file by clicking the Import button. Each row in the .csv or .txt file must contain the following information: app ID, app name.
