Using Custom Fonts
- Select Apps from the web console to navigate to the App Manager.
- Select New App and choose the required app type. The Create App window appears.
                Expand the Font dropdown to select your custom
                    font.
                 Attention: If the chosen custom font is deleted or unsupported, Roboto is used on the IDE and the SOTI Snap agent. Attention: If the chosen custom font is deleted or unsupported, Roboto is used on the IDE and the SOTI Snap agent.
Tip: Administrators can change the font using App Settings while building the app. After
                updating, the newly selected font applies to the IDE. After publishing the app, this
                change is reflected on the SOTI Snap
            agent.
