Creating an API Client
- Manage API Clients permission to add, edit and delete API clients.
Note: If you have an on-premises SOTI MobiControl
				installation, you can still use the old method of creating an API client. See Finding Your Client ID and Client Secret.
				Sign in to the SOTI MobiControl console and from the main
					menu select:
				In the API Client screen, select the
					Add API Client button.
				In the Add API Client panel, enter a
						Name for the new API client.
- Select Generate.
				The Add API Client screen shows the details of the newly
					created API client.
				 Note: Copy and store the client ID and client secret before moving to the next step. After this dialog closes, you cannot retrieve the client secret.Note: The client ID and client secret are automatically generated and you cannot change them.Note: The grant type is automatically selected and is of type Password. You cannot change it. Note: Copy and store the client ID and client secret before moving to the next step. After this dialog closes, you cannot retrieve the client secret.Note: The client ID and client secret are automatically generated and you cannot change them.Note: The grant type is automatically selected and is of type Password. You cannot change it.
- Select the OK button.
				The newly created API Client displays in the API Client
					screen.
What to do next
