XSight OAuth 2.0 Access Token
Endpoint:
/sotixsight/account/oauth2/token
Type: POST
Request
Headers:
Content-type: application/x-www-form-urlencoded
Request Body:
"grant_type": "password",
"username": $username,
"password": $password,
"client_id": $client_id,
"client_secret": $client_secret
Replace the $username, $password, $client_id and $client_secret according to their corresponding key’s description.
Key descriptions:
Key | Description |
grant_type | The grant type used to authenticate. |
username | Username for the account used to authenticate. |
password | Password for the account used to authenticate. |
client_id | API Client Id, this value is generated in | .
client_secret | API Secret Id, this value is generated in | .
To generate the Client ID and Client Secret:
- From the main console menu, select API Clients panel displays.
- Select the Add API Client icon (red box above). The
Add API Client panel displays.
- Enter a Name and Redirect URL and
select the Generate Credentials button to generate the
Secret.
- Copy the generated Client ID and Client Secret.Note: You must copy the Client ID and Client Secret for future reference. Once you leave this page, you are not able to reference these values again.
- Select OK.
Response Headers:
Status Code: $status_code
Status Code | Description |
200 | Success |
400 | Bad Request |
401 | Unauthorized |
Response Body:
"access_token": $access_token,
"token_type": "Bearer",
"expires_in": $expiring,
"scope": "create"
Key descriptions:
Key | Description |
access_token | Token required for authentication when making API requests to SOTI XSight. |
token_type | Type of token returned by the API Request. |
expires_in | Length of time the token is valid for, in seconds. |
scope | Scope of the API Request. |
