Create a New Signal Policy
- Ensure you have Manage Signal Policies. See General Permissions for more information.
Use the Signal policy wizard to define a custom monitoring policy for your environment. A Signal policy monitors managed devices or system components and performs automated actions when specific conditions are met. The wizard guides you through four or five steps to build your policy by:
- Adding general descriptive details about your policy.
- Build Signal Policy Conditions that triggers the policy. You can add many common category conditions (for example, Managed Devices) and many different condition groups (for example, Managed Devices condition groups) to built nested conditions.
- Add Signal Policy Actions that SOTI MobiControl executes under specific conditions.
- (If applicable) Configure Signal Policy Settings for certain Signal policy conditions that requires further configuration.
- Define Signal Policy Schedules that control when the Signal policy takes effect.
To create a Signal policy:
- From the SOTI MobiControl main menu, navigate to .
- Select New Signal Policy to launch the Signal wizard.
Type a Name and Description for
your Signal policy.
