Add/Edit Application Run Control Entry: Path
This topic describes the remaining fields that appear in the Add/Edit Application Run Control Entry dialog box when you select Path in the Policy Type list.
| File Path | Enter the filepath of the application you want to restrict. |
Exceptions
In this section of the dialog box you define any exceptions you want to allow for the restriction.
| Add | Click the Add button to open a menu from which you can select one of the following:
| Edit | Click the Edit button to open a dialog box in which you can make any required changes to the exception that is currently selected in the exception list. |
| Delete | Click the Delete button to delete the currently selected exception from the exception list. |
