Email: IMAP Account
Account Description
Account Name Enter the account name of your organization.
User Enter the user name associated with your email account.
Password Enter the account password here.
Domain Enter the domain name associated with the account.
Sync The Past Select the amount of time email will be synced.
Sync Interval Select the amount of time between each sync.
Incoming Server
Server Enter the IP address or hostname for the IMAP email server.
Port Enter the incoming (IMAP) mail port for the account. 110 is the default port for IMAP
Use SSL This option allows the end user to select whether or not SSL is used for communication with the email server.
Authentication Type Select the type of authentication to be used for this account. (Password is only available)
Re-type Password Re-type the account password here to verify accuracy.
Email Configuration Enter the email address associated with your email account.
Outgoing Server
Port Enter the incoming IMAP mail port for the account.
Alternative SMTP
Use Alternative SMTP Specify whether to use an alternative SMTP account. This is useful when access to primary SMTP server is not available.
Alternative User Name Specifies the display name associated with the user's alternative SMTP email account.
Alternative Password Specifies the password for the user's alternative SMTP account.
Alternative Domain Specifies the domain name for the user's alternative SMTP account.
