Adding and Editing Shifts
Use this process to add, edit and delete shifts from the Battery Prediction chart.
- From Shift dropdown menu on Battery Prediction Chart, select Manage Shifts. You can also select Manage Shifts from the main menu. The Define A Shift panel is displayed.
click the
button. The Add A Shift panel is displayed.
- Type a name for the shift.
- Select the applicable days the shift occurs on.
- Select the duration of the shift, from start time to end time.
- Click Save. The new shift is displayed on the Define A Shift panel. Data for the new shift accumulates starting from the end of the first shift.
- You can edit a shift on the Define a Shift panel by clicking on the shift name, changing any of the available settings then clicking Save.
You can delete a shift by clicking
beside the shift name then clicking
Delete.
