Recommissioning or Deleting Decommissioned Batteries
You can view a list of decommissioned batteries and either recommission or delete them from SOTI XSight. In the event that a battery has mistakenly been decommissioned, you can check it back in.
To view, recommission or delete decommissioned batteries:
Open the Smart Battery Dashboard then click the Smart Battery button
- Select a battery pool from the list at the left side of the page.
- In the Status dropdown menu, select Decommissioned. A list of all decommissioned batteries is displayed.
- Click the checkbox beside one or more batteries on the list. The Recommission and Delete buttons are displayed at the bottom of the page.
- To recommission a battery, click Recommission. SOTI XSight will begin tracking the battery again.
- To remove the battery from SOTI XSight, click Delete.
