Renaming Groups
Once a group has been created, you can rename it at any time. This change is reflected on all existing incidents that belong to the group.
To rename a group:
  1. Select Settings from the main menu.
  2. Click the context menu to the right of the group name you want to rename.
  3. Select Rename to open the Rename Group dialog box.
  4. Edit the Group Name and Group Prefix fields as required.
  5. Click Save.
