Deleting Groups
You can delete an existing group.
Note: All incidents that belonged to the deleted group are marked as deleted in the database and are no longer available for viewing and searching.
To delete a group:
  1. Select Settings from the main menu.
  2. Click the context menu to the right of the group name you want to delete, then select Delete.
    Note: You cannot delete the Default group.
  3. In the Delete Group message box that opens, select the check box and click Delete.
