Customizing the Batteries List
You can simplify the Batteries list according to your needs by selecting which columns are displayed.
  1. Click the Columns View dropdown menu.
  2. Select the columns you want displayed on the list. Choose from the following:
    • Battery ID
    • Manufacturer
    • Device Model
    • Serial Number
    • Manufacture Date
    • Part Number
    • Devices
    • Average Discharge Rate
    • Remaining Battery Capacity
    • Total Charge Cycles
    • Age
    • Last Device ID
    Note: You can use the search field at the top of the dropdown list to locate a specific column. Click Done to apply your changes.
