Integrating SOTI XSight and SOTI MobiControl
This page describes the settings used to integrate SOTI XSight with SOTI MobiControl and creating API clients as a parent of the children related to it.
Setting | Description |
Username | Enter a valid SOTI MobiControl username. |
Password | Enter the password for the above SOTI MobiControl username. |
Default Instance | The name of the default SOTI MobiControl instance that SOTI XSight is integrated with. |
Access URL | The URL of the default SOTI MobiControl instance. |
Client ID | The client ID of the default SOTI MobiControl instance. |
Use SOTI Identity for User Authentication |
If this toggle is switched on, the option for selecting SOTI MobiControl Login becomes available as an option under login mode. |
Enable to support additional SOTI MobiControl Instances |
If this toggle is switched on the section for adding Other Instances and SOTI XSight Management Server Login Configuration becomes available. |
Other Instances |
Note: This section appears when Enable to
Instances is selected. See Adding a SOTI MobiControl Instance.
SOTI XSight Management Server Login Configuration |
Note: SOTI MobiControl Login is
only available if Use SOTI Identity for User
Authentication is switched on.
Automatically create an incident when remote-controlling a device from SOTI MobiControl | Select this option to have an incident created automatically when starting a device remote-control session in SOTI MobiControl. |
Note: After making (and saving) changes, you must restart
the SOTI XSight Management Server for the changes to take
effect.
