About Remote Control
You can access the remote-control feature on the working panel (far left side) of the SOTI XSight Incident page. This feature enables you to remotely control a device so you can diagnose and resolve problems.
To display the remote-control page in a separate window, select .
To move a separate remote-control window back into the remote-control page, select .
Title Bar
Device's context menu | This menu appears to the right of the device name. The device management options available from this menu depend on the group the device belongs to. When you move the device from one group to another, the options change automatically. |
+ Add to Incident | Select this button to add the current device to an existing or new incident. ![]() |
Remote Control Views
The following viewing options are available on a toolbar at the top-right of the remote-control page:
Displays an interactive image of the device. Selecting and dragging on the image using
the mouse pointer emulates tapping and swiping the device touch
screen. When you select this view, the Remote Control Toolbar appears on the right side of the page under the viewing options toolbar. |
Displays snapshot information from SOTI MobiControl about the device
status, battery life and memory usage, (see About the Device Snapshot Page). You can display the same information directly from the
Association panel by selecting the
Snapshot icon, which is active even for
the devices that are currently offline. Note: Requires SOTI MobiControl
View System Info device group permission
(see Device Group
Permissions in SOTI MobiControl
Help). |
Downloads diagnostic files to SOTI XSight and attaches them to
the incident. You can preview these files in the incident details
view. Note: Requires Android device agent version 14.0 or later.
Displays a tree view of the device's file system. You can search the file system for specific files/folders, download, rename, delete, and upload files and folders to the device. |
Displays a list of the tasks currently running on the device. On Windows CE and Windows Desktop devices you can also end running tasks. |
Displays the administration web console for managing devices that lack a user
interface. You do not need to be on the same network as the device.
Note: Requires Linux device agent version 14.3 or later, and
Run Web Console device group permission.
See Device Group Permissions in SOTI MobiControl Help. |
Displays an SSH terminal window for the device. Note: Requires Linux device agent
version 14.3 or later, and SOTI MobiControl
Run Command Prompt/Terminal device group
permission. See Device Group Permissions in SOTI MobiControl Help. |
When you select the Remote Control view, the tools at the right side of the page let you control basic device functionality and adjust the device view.
Magnifies the device view so you see a smaller area in more detail. |
Reduces the device view so you see a larger area in less detail. |
Adjusts the device view so that the entire device appears within the Remote Control page or window. |
Shows the device at actual size. |
Lets you to grab and move (pan) the device view while zoomed in. |
Rotates the device screen clockwise. |
Takes a screen shot of the device and attaches it to the incident. You can then add a description, view, download, or delete the screen shot. |
Starts recording the remote control session. You can pause and resume the recording. When you stop recording, the video is automatically attached to the incident. You can then add a description, replay, download, or delete the recording. |
Lets you, and optionally the device user, draw on the device screen. The bottom of the
page displays a drawing toolbar when using this option. The
following tools are available:
Opens the Preferences dialog box where you can save your preferences for video recording. Preferences include recording mouse-movements and mouse-clicks, displaying the device skin, and selecting the screen capture file format (GIF, JPEG, BMP, or PNG). |
Navigates back to the device's home screen. |
Navigates to the previous device screen. |
Raises the device volume. |
Lowers the device volume. |
Locks or unlocks the device screen. |
Opens the device menu. |
